Home Page Forums Technical Discussion reset to factory Win10 problem iWork10
Viewing 5 posts - 1 through 5 (of 5 total)
2019-05-14 03:00:47
Replies: 4 | Views 6065 | Favorites: 0 | Subscriptions: 1
hello!
i have problem with my iWork10 in reseting process to factory configuration Win10.
I worked with my iWork10 for 2 years. And desided to reset the nootebook and present to a friend.
Reseting procedures worked properly in Android and in Win10. Android was clear and ran initial setup without problem.
In contrast – Win10 asked me the username and password!
What can I do?
myIWORK10
2019-05-17 09:12:39
It is recommended that you reinstall windows os ,
and then restore drivers for i15tc:https://mega.nz/#!aGYEWShD!csFB2U8Ng09X97VIVKTU99AFrzsDyYu9or7Hw8YoTaU
2019-05-17 16:14:55
It is recommended that you reinstall windows os , and then restore drivers for i15tc:https://mega.nz/#!aGYEWShD!csFB2U8Ng09X97VIVKTU99AFrzsDyYu9or7Hw8YoTaU
reinstall? it’s the the tablet PC. How can i do that? At the first time i did the basic win10 function.
Is there the factory function somethere? I have no software somethere on disk or something :,(
2020-07-26 04:55:53
hello Dear
I have the same problem
ok thanks but there are many other tricks
but there is problem to run the “command prompt” or 5 times SHIFT if there is login place but all 2 options doesnt work with this system
can you send inf. how I can RUN the command prompt ?
thanks
Czarek
2020-07-26 04:57:08
Also the safe mode doesnt work 🙁 and cant change password  – why these functions are OFF ? how can we ON it ?
regards
Czarek
