Home Page Forums General Discussion iplay20 and youtube vanced issues
Viewing 10 posts - 1 through 10 (of 11 total)
2020-10-20 06:05:56
Replies: 10 | Views 12252 | Favorites: 0 | Subscriptions: 4
Hello,
I’m having issues with youtube vanced and the iplay20. Many videos are locked to a low resolution without the option to change the resolution as the quality setting won’t apper for them. They do however play in 1080p when playing them in youtube mobile site using chrome.
For other videos I don’t have that issue and they play in 1080p and I have the quality setting available for them.
Does anyone else here have youtube vanced on this tablet with the same issue? Any idea how to resolve this?
Screenshot_20201012-160559
2020-10-22 18:43:06
Hey there, I had the same issue. What seems to have fixed it for me was going back to stock Youtube. Go to Settings -> Apps & notifications -> YouTube . There should be 3 vertical dots on the top right, tap on it and uninstall all updates. After that go to the google play store and stop auto updates. Tell me if that works for you.
Edit: Just read its for youtube vanced, I’m not sure how to fix it for that, but the above fix works for the normal Youtube app
2020-10-28 03:18:15
Thank you for your answer. I didn’t realize that the normal YouTube app had the same issue, but going back to an older version of the app fixes the problem for both apps.
Hopefully this will be fixed with the next firmware update.
Bigio80
2020-11-03 04:54:13
Hello, I had the same issue.
With same video of YouTube and under same internet connection, in a Samsung Tablet I see video in best resolution (1080p) but in the iPaly20 table video is very low quality and I can’t select the option to upgrade video quality.
Of course i have bought this tablet for watch YouTube video first but this basic function is not working like must work so this tablet is not good and useless.
The solution of rollback YouTube app version I think is not a solution because the issue must be resolved otherwise this tablet is only rubbish.
2020-11-03 06:56:46
I’ve contacted Alldocube’s support regarding this issue and they’re blaming youtube, even though these videos work perfectly fine on any of my other devices.
They’re not even willing to acknowledge that this is an issue with their hardware or software, so I guess it will never be fixed. What a shame.
Bigio80
2020-11-04 05:53:36
Thank you for your replay.
So, I can say that I have made a mistake to choose this tablet instead other more know brand.
This tablet (iPlay 20) is a totally rubbish.
I never buy again some other devices from Alldocube.
Wast of money.
2020-11-13 07:59:01
Good news! From what I’ve seen so far it seems that the resolution bug is fixed with the latest youtube update.
Finally I can watch youtube in 1080p.
Bigio80
2020-11-13 08:47:04
Is a miracle!!!!
I confirm, after last YouTube app update it seems that the resolution bug is fixed!!
Right in these day I have write about the problem at the Aliexpress officiall seller where I have buy the tablet.
They ask me to take a video about the problem and….incredible….problem was fixed!!
Maybe it was my success!
2024-09-12 23:13:02
I was having trouble with iPlay20 and YouTube Vanced recently. The issue was resolved by updating both apps to the latest versions. I also cleared the cache for YouTube Vanced and reinstalled both apps. Restarting my device helped too. If you’re facing similar problems, these steps might solve them for you as well.
vanced7
2025-04-16 12:38:18
#10F
I’ve been having trouble with iPlay20 and YouTube Vanced recently. Updating both apps to the latest versions fixed the problem. I also cleared the cache for YouTube Vanced and reinstalled the apps. I also restarted my device and it worked fine. If you’re having the same issues, the above should also resolve them for you.
